Results 1 to 6 of 6
Thread: Collection of Dynamic Symbols
    2022-02
    7
    Lightbulb Collection of Dynamic Symbols
    I use a lot of these daily for PID drawings.
    Some have gone through many versions to get here.
    Hope you find some useful.
    2022-02
    7
    Default Re: Collection of Dynamic Symbols
    Need to mention on the Flange Block. I have yet to figure out the difference between Angle and Rotate, but the stretch action only works with rotate not angle. My work around was to add an Alignment parameter. Just snap the block to a line at any angle, and the Stretch works fine.
    Cheers
    2011-10
    Norfolk England
    57
    2
    Hi
    Not sure if you're into vb
    I created these for my own use and have found them quite handy, I am now retired and only use Acad occasionally, so am sharing the fruits of my labours, warts and all, with any one who cares to make use of them.
    Geoff
    updated 20-9-23 cuix file now contains ribbon features
    Turlock, CA
    6,421
    Looks like you put a lot of work into those blocks.
    C:> ED WORKING....
    LinkedIn
    2011-10
    Norfolk England
    57
    Hi Ed
    Yes I suppose I have but I found it easier to use vb to produce these, than have dozens of different fittings in one block.
    Same as the Steel and Piping components vb utilities I have posted.
    Not only that but blocks produced with the vb have the name of the component, so when highlighted shows what the component is, and not just a generic name, if that makes sense.
    I was in structural and piping engineering for best part of quite some time and have been using cad since the early 90s but at present I'm just fiddling with things to pass the time.
    Thx for all your input
    No wonder you're classed as 'Professional'
    Thx again Geoff
    Turlock, CA
    6,421
    Anyone can be a professional member. One of the best perks is the highly discounted rate for being an ADN member.
    C:> ED WORKING....
    LinkedIn
  1. Replies: 8
    Last Post: 2022-07-22, 06:57 AM
  2. Replies: 0
    Last Post: 2011-12-15, 02:02 PM
  3. Imported CAD symbols VS Annotation 2D symbols
    By Binu Mathew in forum Revit MEP - General
    Last Post: 2009-12-30, 03:36 PM
  4. Civil 3D, and Data Collection?
    By josealzamora in forum AutoCAD Civil 3D - General
    Last Post: 2004-12-18, 01:51 AM
Tags for this Thread
