Thread: change wall style and width changes
    2003-08
    99
    Default change wall style and width changes
    I have a wall style definition for existing walls, only 2 lines, set to base width, with all items on layer 0, color and line type by layer. I put the Exist Variable walls on a A-Wall-Existing layer. When I attempt to change a different style wall to this Exist Variable style because the building has been built, the overall width of the wall will change to some arbitrary width. What was a 3-5/8" metal stud wall with 5/8" gwb ea side (4-7/8" total width) will become whatever Autocad wants. When style changed to Exist Variable it could become a 12" wide wall. Could be 2-1/2" wide wall. Is there any way to maintain the overall width of the original style when changing it to another simpler style.
    Turlock, CA
    6,421
    Default Re: change wall style and width changes
    Can you post a sample of walls with the 2 styles?
    C:> ED WORKING....
    LinkedIn
  1. 2014: wall width definitions and wall styles
    By jrb63 in forum ACA General
    Last Post: 2018-12-25, 02:34 AM
  2. Replies: 1
    Last Post: 2018-01-31, 02:45 PM
  3. 2016: AIR TERMINALS: Whats the difference between "width" and "duct width"?
    By danezeq390391 in forum Revit MEP - General
    Last Post: 2016-08-02, 09:42 AM
  4. Replies: 4
    Last Post: 2012-09-04, 06:11 PM
  5. Swath Width Changes
    By bryanf in forum Civil 3D - Civil Design Companion - General
    Last Post: 2005-04-01, 01:05 AM
Tags for this Thread
