Results 1 to 1 of 1
Thread: Column "off grid" value on schedule, has choices?
    2005-06
    in the upper right corner
    3,510
    Default Column "off grid" value on schedule, has choices?
    Hello AUGI!
    This is more of a discovery than a question.
    I just recently found that a column location in a schedule (that is on one grid but offset from another) had a choice to show on the schedule.
    I have a column ON grid 2 and offset 5'-11" from D.5, so you would assume show up as "D.5(5'-11")-2" on the schedule.
    Well it did not, it defaulted to an offset of 1'-9" from grid 1.9, showed up as "D.5(5'-11")-1.9(1'-9")" which blew my mind, I made sure it was ON grid 2.
    Then, while in the schedule, picking the column, I saw there was a pull-down option to pick the other one, so I did.
    I'm glad I could do that but don't understand why that would not pick the more obvious location being ON grid 2.
    I hope this helps someone else out there, and if anyone knows why it would behave like this let me know please.
    (Revit, Structure, 2019)
    Have a good one!
  1. 2019: Linked model column grid / grid head control
    By tedg in forum Revit - Platform
    Last Post: 2019-09-09, 04:13 PM
  2. Replies: 0
    Last Post: 2013-07-26, 11:11 AM
  3. Off-Grid Dimension Reference in Column Schedule
    By j.pilot in forum Revit Structure - General
    Last Post: 2011-10-05, 06:56 PM
  4. Replies: 5
    Last Post: 2009-04-17, 10:10 AM
  5. Column Grid Lines and Shifting Column Grids
    By .chad in forum ACA General
    Last Post: 2007-11-02, 03:42 PM
Tags for this Thread
