Results 1 to 8 of 8
Thread: Start Up Lisp Help
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    980
    Question Start Up Lisp Help
    In this Zip file you will find to lisp files. How would I add this (fixtextstyle.lsp) to the Phc lisp so that it will be automatically loaded?
    Thank you,
    Brad
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Default Re: Start Up Lisp Help
    Two ways:
    (autoload "fixtextstyle.lsp" '("fx"))
    or
    (load "fixtextstyle.lsp)
    The first way autoloads the routine on first use and will be stay loaded for the rest of the drawing session.
    The second way loads the routine when it comes to it when that LISP is run.
    I thought
    (defun c:RemArchT (/)
    (c:RKTI)
    (c:RURL)
    looked just fine, but didn't really look at the rest of the routine.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by todw
    Two ways:
    or
    I thought
    (c:RKTI)
    (c:RURL)
    What type of problems are you having regarding the loading of the fixtextstyle.lsp? As todw responded on your question, you need to load the file with [code[(load "fixtextstyle.lsp")[/code] You would then call the function name you are trying to run (c:fx)
    Being that a "STYLE" is not an entity, I don't believe you can modify the "STYLE" with entmod. (I could be wrong)
    2003-04
    Bethlehem, PA
    980
    Question Re: Start Up Lisp Help
    Quote Originally Posted by richardl.25628
    Do I add what todw said to the fixtextstyle.lsp or the the Phc.lsp? If I add it the the Phc.lsp how would it look?
    2002-01
    jUSt Here (a lot)
    9,100
    Post Re: Start Up Lisp Help
    Quote Originally Posted by BCrouse
    You would need to add it to the phc.lsp file
      ; This will load the fixtextstyle.lsp file.  This file must
      ; be able to be found within your support directories.
      ; This then runs the c:fx function as you have it defined
      ; in the fixtextstyle.lsp file
    (c:fx)
    Again, I do not think you can entmod a text style.
    I hope this helps.
    2003-04
    Bethlehem, PA
    980
    Thank you todw and richard.25628 for your help. I got it to work now. How could I get this to update and save the text styles when publish is running? Is it possible? How could I get this to update dwgs that are xref'd?
    Thank you,
    Brad
    2000-01
    Seattle WA USA
    5,859
    Code will not execute in a background publish operation.
    I could stop if I wanted to tyshofner's Avatar
    2004-03
    Dallas, Tx
    229
    I'm not sure that this is possible, you could get the routine to change width factors or actually change the style (thats change the style that a text object uses, not the actual "style") in the current drawing, but it's not very practical plus the changes will be undone as soon as the xref is reloaded. Your best bet is to just run the routine on each individual drawing.
    Ty
  1. Dim Style Lisp help - where to start
    By gfreddog in forum AutoLISP
    Last Post: 2009-12-04, 07:31 AM
  2. Learning how to use Reactors in LISP, where to start
    By rajat_bapi_mallick in forum AutoLISP
    Last Post: 2007-05-25, 03:05 AM
  3. Replies: 6
    Last Post: 2007-04-27, 05:54 PM
  4. Replies: 5
    Last Post: 2006-12-08, 03:20 AM
  5. Loading lisp code at start up
    By cadd4la in forum AutoLISP
    Last Post: 2006-01-31, 04:45 PM
