Thread: Legend Flip Controls??
    I could stop if I wanted to Shaun v Rooyen's Avatar
    2005-02
    337
    Exclamation Legend Flip Controls??
    The door family I created is flipped in the project via it's blue controls. Now when it comes to placing it in as a legend component I can't flip it. Its orientation is as the families.Ie flip hands. Once the family is edited it disappears from the legend after reloading. Mirror doesn't work either. aargghhh
    2004-11
    116
    Default Re: Legend Flip Controls??
    I having the same problem...Can you share your solution? And It cannot be TAG...!!
    2015-10
    Wellington , NZ
    565
    Hi,
    I have had similar problems with window (eg.) instances for say RH sashes then LH sashes - flipped in plan views but not able to do so in Legends.
    I was advised that as of Revit 8.1, this is a limitation inside Revit.
    I was advised also that the factory are well aware of it and will get to it. I am sure they will, but will be most happy when this small but very annoying flaw is corrected.
    In meantime, I have been going back to Family Editor to make the additional types - time consuming when a lot of projects are one off for windows particularly, but does get the necessary graphic correct for W&D graphic schedules.
    good luck.
    trombe
    I could stop if I wanted to Mike Hardy-Brown's Avatar
    Melbourne, Australia
    282
    Zeds...
    Try do a legend of a corner window...aaaargh indeed. "Drafting Lines" was my solution
  1. 2011: Flip Controls within a family
    By ckidd in forum Revit MEP - Families
    Last Post: 2011-07-27, 06:14 PM
  2. We need vertical flip controls
    Last Post: 2009-04-14, 04:26 AM
  3. Flip Controls... WTF
    By azmz3 in forum Revit Architecture - General
    Last Post: 2009-03-25, 10:50 PM
  4. How To Remove Flip Controls
    By Scott.Reagles in forum Revit Architecture - Families
    Last Post: 2006-05-08, 11:21 PM
