Results 1 to 10 of 14
Thread: Turn off UCS?
    2005-03
    14
    Default Turn off UCS?
    The UCS always seems to be in my way and I usually don't need it. In previous version of AutoCAD I have been able to add a toolbar button to quickly toggle it on of off. I can't remember the name of the function or seem to find it in 2006. Can anyone help me?
    2004-05
    14
    Default Re: Turn off UCS?
    UCSICON = OFF
    2005-03
    14
    Thanks, but how do I add a button on the toolbar or a shortcut to do this?
    150700
    3,439
    Quote Originally Posted by jhunter
    What version of AutoCAD are you using
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Here is my small code to do this.
    (defun c:ui ()
      (setvar "ucsicon" (abs (1- (getvar "ucsicon")))) ;; toggles the ucsicon on/off
    I hope it helps.
    2005-03
    14
    Thanks, but I don't know what to do with the code.
    150700
    3,439
    If you know how to add a button to your toolbar, this is the command to put on it. ^C^Cucsicon;off You might want to check the help file for customizing tool bars, it is new in 2006, and I really haven't had a chance to check it out.
    Also, if you turn it off in your template file, all new files creating using that template as a starting point will have it turned off
    2005-03
    14
    OK, I setup the button with the code you posted. But it dosn't work, it just shows the code in the command line.
    150700
    3,439
    Do you have a space after the word off in the command?
    2005-03
    14
    I tried it both ways, with and withough a space. Same result.
  1. Turn off help
    By Revit for Breakfast in forum NavisWorks - General
    Last Post: 2012-04-13, 04:22 PM
  2. How do you turn dwg files into nwd?
    By BTroxell in forum NavisWorks - General
    Last Post: 2009-01-09, 05:34 PM
  3. Layers will not turn on
    By jlahmon in forum AutoCAD General
    Last Post: 2008-11-26, 07:01 PM
  4. More than one turn
    By slim13 in forum Revit Architecture - General
    Last Post: 2004-06-14, 01:08 AM
