Thread: Delta symbol needed in curve labels LD 2005
    2002-01
    Scottsdale, AZ
    4
    Default Delta symbol needed in curve labels LD 2005
    Does anyone know what the extended character formula is for the delta symbol (triangle)? I can't seem to find anything that works with the simplex font in curve labels.
    thanks,
    ~Becky
    Member ksteele's Avatar
    2000-10
    Sunny Northwest Florida
    15
    Wink Re: Delta symbol needed in curve labels LD 2005
    Unicode Strings, Control Codes, and Special Characters
    You can enter the following control codes and Unicode strings to create special characters. Unicode strings and control codes
    Control Codes
    Unicode Strings
    Result
    %%d
    \U+00B0
    Degree symbol (º)
    %%p
    \U+00B1
    Tolerance symbol (±)
    %%c
    \U+2205
    Diameter symbol ()
    Note that the circle diameter dimensioning symbol appears as %%c in the Multiline Text Editor but converts to the special character in your drawing.
    The following text symbols can also be inserted by entering the appropriate Unicode string or from the MTEXT shortcut menu: Text symbols and Unicode strings
    Name
    Symbol
    Unicode String
    Almost equal
    \U+2248
    Angle
    \U+2220
    Boundary line
    \U+E100
    Centerline
    \U+2104
    Delta
    \U+0394
    Electrical phase
    \U+0278
    Flow line
    \U+E101
    Identity
    \U+2261
    Monument line
    \U+E102
    Not equal
    \U+2260
    Ohm
    \U+2126
    Omega
    \U+03A9
    Plate/property line
    \U+214A
    Subscript 2
    \U+2082
    Superscript 2
    \U+00B2
    These text symbols are available in the following True Type (TTF) and SHX fonts:
    Simplex
    RomanS
    Isocp
    Isocp2
    Isocp3
    Isoct
    Isoct2
    Isoct3
    Isocpeur (TTF only)
    Isocpeur italic (TTF only)
    Isocteur (TTF only)
    Isocteur italic (TTF only)
    Kimberly Steele
    2002-01
    Scottsdale, AZ
    4
    Default Re: Delta symbol needed in curve labels LD 2005
    Unicode strings such as \U+0394 don't work in Curve labels - only in Mtext. And you can't Mtext edit curve labels either. Thanks for replying.
    I actually found the solution on my own late last night.... it's {delta symbol} if anyone else needs it. It doesn't look like it's going to work when you're in the Edit Label Styles dialog box but it actually does work when you add the labels in your drawing.
    ~Becky
  1. Alignment Curve Labels
    By jacunningham in forum AutoCAD Civil 3D - General
    Last Post: 2011-11-16, 01:48 PM
  2. Delta symbol in revision schedule
    By robertlgibbsjr in forum Revit Architecture - General
    Last Post: 2007-03-08, 04:47 PM
  3. Replies: 17
    Last Post: 2007-02-02, 07:41 PM
  4. Curve labels
    By travis.103818 in forum Land Desktop - General
    Last Post: 2006-10-16, 04:07 PM
  5. curve tag labels
    By chrisw.94380 in forum Land Desktop - General
    Last Post: 2005-09-28, 02:34 PM
