The attached pdf is an elevation and basic section of a typical exterior wall construction we are using. The numbers relate to construction and materials as follows:
1 - split face block on wood stud, fixed height
2 - stucco on wood stud (exterior core face lines up) fixed height
3 - prefinished metal on plywood (applied to exposed end of wood truss - includes an air space and sheathing that line up with the sheathing on wall types 1 and 2)
Right now we have the above as a stacked wall, which is causing some difficulty because when we attach the stack wall to the roof, the core of 2 goes all the way up. To solve this, we have not attached the wall but used the layer extend and pulled 3 up to underside of soffit.
Now we have two more issues which relate to finishes and applications, which are the following materials:
4 - replace stucco finish on wall type 2 above with prefinished metal bonded to plywood - only between windows (same finish material as 3 above and in same plane)
5 -provide a continuous wood band above window frame - not part of a wall type right now
6 - concrete sill is a sweep included in wall type 1
Two questions are:
Should we have such a complex wall or should we just stack 1 and 2 and apply 3 as a sweep (it is not continuous around the face of the building). If so, should the wood band be part of this applied wall type or sweep type? If we do this, then would we take the sheathing and furring for wall type 2 all the way up and just apply the plywood to that face.
We don?t want to introduce another wall type in which we replace the stucco with the panel (type 4), so is there some way we can replace the stucco layer in section and plan or apply it to the elevations as a vertical sweep. What we want to be able to do is have the panel flush with the adjacent stucco.
A little complicated for our first project, but if we can sort this out, we can tackle anything, I think!
Update...
we decided to use a wall reveal to create the metal panel between and beside the window openings. Found out can't place the reveal right beside the window frame and if you want the reveal to continue past the frame in either horizontal or vertical, use centre line for insertion. Not bad so far...
Now I have horizontal reveal above and below window that I want to be continous and I have vertical sweeps adjacent to windows that I would like to but(t) into the horizontal. I end up with an extra piece of sweep where the two cross over each other. I tried shortening the vertical and copying it.
So... is there a way to either have the vertical or horizontal supercede the other or "hide" behind the other material? Or is there a way that when two sweeps cross each other in a cross or grid, that they combine together and join?
thanks again..
...help!
