Results 1 to 6 of 6
Thread: Construction Drawings
    2005-03
    57
    Default Construction Drawings
    hello,
    I want to create construction drawings from my project.
    Therefore I have to delete all inner walls but have to retain my outer walls.
    the only things visible in my drawing are the columns and beams and outer walls.
    How is this possible in Revit.
    I have to draw the span lines and stability measures
    Hoping somebody can help me
    greets Maarten
    AUGI Addict luigi's Avatar
    2003-05
    Royal oak, Michigan
    1,509
    Default Re: Construction Drawings
    The only way I know of (actually 2) is to either divide them in phases, which won't take too long, just a few seconds (ok, maybe a minute), or
    create worksets (which unless you will have a few more people helping out I wouldn't suggest it) and divide the building shell with the interiors
    Both of them will work....is there any other way guys???
    All AUGI, all the time Elrond's Avatar
    2004-03
    Hereford, UK
    820
    Can't do subcatagories for system families such as walls - so worksets is your best bet. They are very easy to create and use for what you need.
    Elrond
    Elrond Burrell, Architect
    [Connect with me on LinkedIn or Twitter]
    "The best time to plant a tree was 20 years ago. The second best time is now."
    - Chinese Proverb
    I could stop if I wanted to cosmickingpin's Avatar
    2004-05
    North of the 49th
    475
    I am still working in version 7.0 but you can make all of you exteroir walls "bearing" and you interoir walls to "non-bearing" that way when you create a floor plan and set its discipline to "structrual" only the "bearing walls" will show up along with your columns and beams. Your non bearing walls will not show up and will be filtered out.
    Quote Originally Posted by mwittens
    hello,
    greets Maarten
    "Rock-n-Roll Architect" SCShell's Avatar
    2004-01
    Tucson, AZ
    1,272
    Hey there,
    Another option is to use Options. (sorry!) Just start a new option "interior construction" and select all interior items you want separate and click "add to option". Then, just set up your view to shown whatever option you want.
    Good luck
    Steve
    Steven C. Shell, Architect
    Tucson, Arizona
    www.scshell.com
    2005-03
    57
    Thumbs up Re: Construction Drawings
    Quote Originally Posted by cosmickingpin.67846
    this is a really great option. It works fantastic.
    Thanks you all
  1. Construction Drawings Samples?
    By Vaioarch in forum Revit - Gallery
    Last Post: 2005-08-29, 02:20 PM
  2. Construction drawings in Revit
    By Nic M. in forum Revit - In Practice
    Last Post: 2005-02-14, 05:46 PM
  3. Construction Admin. Drawings
    By LarryG in forum Revit - In Practice
    Last Post: 2004-10-01, 03:49 AM
  4. Revit for UK drawings and construction
    By dg in forum Revit Architecture - General
    Last Post: 2004-05-15, 01:25 PM
