Results 1 to 7 of 7
Thread: Newbee imperial to metric question
    I could stop if I wanted to Griff's Avatar
    2003-12
    Idaho
    291
    Default
    I have been trying to get most of my questions answered by searching previous post and have been pretty lucky, but I can't find this one:
    Is it possible to draw a project in imperial units then switch over to metric?
    I have customers that like imperial (which I think in) and others that insist having the CD's in Metric.
    Dave Griffith
    2003-05
    5,153
    Default Re: Newbee imperial to metric question
    Yes.
    Select Setting > Units > Feet and Inches or what have you.
    Draw away happily.
    Reset Units to Metric.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    Mastering Revit Author JamesVan's Avatar
    2003-04
    New York, NY
    624
    Sure can. Just make sure you aren't using any dimension types that override the project unit settings. Then go to Settings-Project Units, change all to the Metric setting of your choice.
    We are the music makers...we are the dreamers of dreams.
    All Things BIM
    Visit the Revit Community Home Page
    2003-12
    Idaho
    291
    Thanks for the help. I haven't looked at the dimension styles yet, but I wanted to make sure I could start the project in imperial units and then switch over to metric at the end.
    Thanks also for the time about not setting any dimensions to override project settings.
    Dave Griffith
    2003-08
    Vancouver, BC Canada
    3,392
    Griff,
    One other neat trick Revit does for you on the fly. Once you convert your units not only do dimensions change but area tags, area schedules etc. will also change. I just completed a project where the city required areas to be submitted in metric and the client wanted the dimensions in imperial. I changed only the unit settings for area and the area schedule was updated to metric while the dimensions remained imperial so the client could relate.
    You can also switch over and back at any time through the process.
    ____________________________
    Dimitri Harvalias LEED AP
    Summit BIM Consulting
    BIMblog.ca
    I was never just a CAD monkey, so I refuse to be a BIMpanzee!
    A BIM without the 'I' is just a BM - those in the medical profession know what that amounts to
    2003-12
    Idaho
    291
    This software is impressive!!!!!!!! I can't imagine what I'm going to be able to do with our projects.
    I've been reading all the hoopla about how exciting 6.0 is and I can't get over the high I'm on just seeing all the capabilities of 5.1 !!!!!
    Dave Griffith
    2003-07
    Jerusalem
    64
    I previously reported, that there was a problem in switching from cm to meter and cm.
    In Revit 6 it looks like that the conversion of the different units is now working properly.
    Great! Thanks.
    I did not find any paper, in which Autodesk indicates, which bugs actually were eliminated in Revit 6. Guess it could be helpful if such information would be accessible somewhere.
    gerhard
  1. Metric to Imperial
    By ..shaner in forum Revit Architecture - General
    Last Post: 2009-08-21, 06:43 PM
  2. Question d'un newbee :
    By neo750 in forum Revit Architecture - Général
    Last Post: 2009-05-08, 06:12 PM
  3. NewBee Question on VB for Inventor.
    By kb3cxe in forum VBA/COM Interop
    Last Post: 2008-08-11, 03:04 PM
  4. Imperial to Metric
    By rhayes.99001 in forum ACA General
    Last Post: 2008-06-18, 08:36 PM
  5. Metric to Imperial
    By Old Jim in forum Land Desktop - General
    Last Post: 2006-01-27, 07:32 PM
