Thread: 2 Questions - Curtain Wall Panels and Sloped Glazing
    2005-04
    Ontario, Canada
    257
    Default 2 Questions - Curtain Wall Panels and Sloped Glazing
    I have two questions regarding the use of curtain walls.
    (1) Curtain Wall Panels.
    I created a curtain wall system with a pre-defined grid layout. I want to change the color that several of the glass panels render, is there a way to change a group of panels without having to select them one by one and change their colour / material?
    (2) Sloped Glazing.
    I changed a roof to sloped glazing to create a standing seam metal roof. Once I do this, I loose my roof thickness (structure) capabilities. How would you go about getting a roof thickness showing again below the sloped glazing? Do I need to apply fascias and soffit? Is there a way to apply sloped glazing overtop of a basic roof, rather than changing the roof itself to sloped glazing?
    C. Stechyshyn
    2003-05
    5,153
    Default Re: 2 Questions - Curtain Wall Panels and Sloped Glazing
    (1) Draw selection box around the panels to be changed. Filter down selection to Curtain Wall Panels only. Swap existing panels for new panel type.
    (2) I think you’re missing the step to change the glass panel to a roof panel having a thickness and offset, after you’ve created the mullion. – see attached.
    2005-04
    Ontario, Canada
    257
    Question Re: 2 Questions - Curtain Wall Panels and Sloped Glazing
    beegee,
    Thanks for the help, I took a look at your suggestions and have a question regarding the first question I had asked....
    (1) After selecting a group of panels, where do I find a "filtering" option? I tried using "TAB" but it only selects a single panel within the selection group.
    C. Stechyshyn
    I could stop if I wanted to Damo's Avatar
    2004-05
    London, UK
    326
    Quote Originally Posted by artitech
    It is the little 'funnel' icon to the right of the 'Type Selector'
    2005-04
    Ontario, Canada
    257
    Someone pointed this out to me at work today as well.....
    C. Stechyshyn
  1. 2014: Using curtain walls and sloped glazing for insulated wall panels
    By Jozi in forum Revit Architecture - General
    Last Post: 2015-03-28, 01:24 AM
  2. 2012: PROBLEM WITH SLOPED GLAZING CURTAIN PANEL
    By Bastiat in forum Revit Architecture - General
    Last Post: 2013-02-04, 01:57 AM
  3. Problem with Sloped Glazing Roof Panels
    By dvanburen in forum Revit Architecture - General
    Last Post: 2006-11-07, 02:43 AM
  4. offset glazing panels in a curtain wall.
    By brendan.mac in forum Revit Architecture - General
    Last Post: 2006-02-06, 10:53 PM
  5. 2 Questions - Curtain Wall Panels and Sloped Glazing
    By artitech in forum Revit Architecture - Families
    Last Post: 2005-05-04, 03:28 AM
