I think the most misunderstood problem people have with Revit and detailing is that when people say Revit is no good for detailing I think this is why - Its not that they cant draw details, that is fine -but that with Revit you cant manage them.
It has always amazed me that I can edit and update anything I like parametrically or by reloading with Revit except for the most important things - THE DETAILS!!, by this I mean fully drawn, finished working details. not the parts that make them up, ie detail components - Working detail drawings are completely dead entities in terms of Revit. I cant link them, load them, save them, update them..... I use my details across many projects, not just in one model. I need a way to be sure the projects I want to be are up to date, and the ones I want archived will not change.
I need a new type of family called a DETAIL. This family should have the same properties as a DETAIL COMPONENT mentioned in my previous thread - ie I can copy/paste into it from models etc, but importantly it can contain text as well this text and leader arrows would come in with the family in the same way as labels do in other families...
That way I would use this new family to create, edit and store fully drawn details, I could then have a meaningful and manageable detail library using Revit on its own. I would be able to update details in projects by loading these DETAIL families. At the moment Revit has no means of updating details other than pasting in the new one and deleting the old out of date one
EDITED>>>>> why groups are not a solution <<<<<<<<<
As to edit groups you have to -open a project, locate group, load, place, edit group, edit the lines,add to group, finish group, save, close project - then locate it, load into your project, place it..... - you are doing quite a bit more work than should be required. Major alterations often require an ungroup - you then cannot save over the existing group name!!!!! Saving details out as groups hasnt got any great benefit as far as I can tell, you cant open them on their own and groups are a pain to alter when it comes to details (load group,edit group, add to group, finish group,save group - hopefully without having had to ungroup..........) - in my experience I have found it quite a hindrance to be honest as it takes quite a lot of time to alter them for no real benifits.
A family for details would have a lot of benefits over using groups. Unless groups are changed in some way to allow us to OPEN saved groups in their own right and work in them - and/or to work in them whiles in EDIT GROUP mode. Rather than the lots of superflous steps we have at the moment, to simply edit a group you want to use a detail. At the moment it takes far to long just to edit them to be a real solution...
