Thread: connection to sql database
    2005-02
    7
    Cool connection to sql database
    my directive this year is to take all floor plans, have them automatically update [office occupant first name & last name, phone number, department assignment] from a SQL database specifically being setup for the AutoCAD drawings to access. I've worked on drawings other places where all this has already been set up and the database existed on the same workstation.
    couple of notes:
    the database is on a server in another building.
    nothing has been set up within the drawings for this information yet. these are legacy drawings for five cities that I've lovingly inherited.
    suggestions?
    2000-01
    Seattle WA USA
    5,859
    Default Re: connection to sql database
    Do a lot of reasearch on Database Connectivity. Read up on AutoCAD's DBConnect feature. If you plan on writing code, get Scott McFarlane's Database Connectivity book (outdated, but an excellent starting point). Try the samples in AutoCAD's sample folders.
    2005-02
    7
    Cool Re: connection to sql database
    Thanks for the help. Now they're wanting to avoid having databases within the system that are not of absolute necessity and are wanting to find out if AutoCAD will connect and pull from Active Directory. basically, taking out the middleman.
    thoughts?
    AUGI Addict Eric Wing's Avatar
    2003-02
    Syracuse, NY
    1,122
    Quote Originally Posted by sdickson
    thoughts?
    There is an ATP Class for August that addresses data links from a DB source. It's not exactly what you are asking for, but does explore some options.
  1. Connection database with Excel and Autocad
    By luislhss in forum VBA/COM Interop
    Last Post: 2020-05-15, 06:40 PM
  2. 2015: DataTools Connection to Published NWD file with Embedded Database Properties
    By Ciseckid684387 in forum NavisWorks - General
    Last Post: 2015-02-06, 04:17 PM
  3. [Revit-Robot connection] Missing custom database in "Mapping of elements" window
    By StroocturalEng in forum Robot Structural Analysis
    Last Post: 2012-05-06, 05:36 PM
  4. AutoCAD 2011 and creating in database connection
    By svest in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2010-09-24, 01:33 PM
  5. Database Connection to SQL Server
    By dasmith in forum AutoCAD Map 3D - General
    Last Post: 2005-02-02, 09:18 PM
