I attended a presentation on the 2006 Upgrade last week and the presenter's knowledge of how Map Book works was very limited, so he was unable to answer this question. I'm still using Map 2004, so I asked if the Map Book would give intelligent titles to the dwf files it creates, such as using the query title as the file name. (In previous versions of the program, it used randomly assigned numbers for titles, so we've used an add-on called "plot map set add-on" to fix this problem.) For those of you using the 2006 version, have you tried to run a set of maps based on queries you've saved? If so, were the titles something logical? If it's not saved with the query title, what is it saved as? I've ordered a demo disc, but while I'm waiting for it to arrive, I thought I'd check to see if anyone's worked with it yet.
Thanks!
I explode MTEXT.
