Thread: REVISION NUMBER
    2004-11
    115
    Default REVISION NUMBER
    I HAVE A 5 SHEET WHICH HAS A SAME REVISION NUMBER BUT DIFFERENT REV. DESCRIPTION. BUT I DON'T KNOW IF IT IS POSSIBLE?
    2003-04
    Irvine, CA
    6,777
    Default Re: REVISION NUMBER
    Quote Originally Posted by alvin.78712
    If you are hoping to itemize or summarize the things that changed on each sheet during Revision 1 for example. You might consider placing notes on each sheet that fully explain what the revision entailed and let the simple description in the schedule say, "General Revisions, Refer To Sheets"
    Just a thought.
    2004-11
    115
    Well. thanks thats the only thing I can do or do it manually.
    I could stop if I wanted to David Conant's Avatar
    2003-05
    Waltham MA
    286
    Please post a simple mock up of what you are trying to achieve. Visual aids will help us better determine what you need.
    David Conant
    Autodesk Revit
  1. Revision Number vs. Sequence
    By twollifur in forum Revit Architecture - General
    Last Post: 2010-07-12, 01:13 AM
  2. Revision Cloud With Number
    By SHAJU in forum AutoLISP
    Last Post: 2009-05-20, 07:50 PM
  3. Current Revision Number
    By nextvkin in forum AutoCAD Fields
    Last Post: 2009-01-19, 10:37 AM
  4. Revision Cloud without Number
    By veronica.lamb in forum Revit Architecture - General
    Last Post: 2006-10-23, 08:42 PM
  5. Changing revision number tag how?
    By Wagurto in forum Revit Architecture - General
    Last Post: 2005-09-21, 08:21 PM
