Thread: etransmit
    2004-02
    10
    Question etransmit
    I'm using ADT 2004 and I'm trying to compress the entire project. i attempted to try etransmit. and it seems to be based on one file. do i have to pick EVERY file w/ add file?
    can anyone please give me some assistance. thanks for your time and any help given.
    2002-09
    Madison, WI
    5,687
    Default Re: etransmit
    Right click on the constructs tab in PN and you can -transmit all of the constructs at once,
    Do the same with the views and the sheets.
    2004-02
    10
    Question Re: etransmit
    thanks dave. when i right click on the PN tabs nothing happens????
    2002-09
    Madison, WI
    5,687
    Pick on the constucts tab.
    When the constructs listings come up, you should see some type of a file tree.
    I must not have explained myself correctly.
    scroll up to the top of the constructs listings, you should see a file folder that says "construct" in the white space of PN. Right click there. This also work for individual drawings and sub folders
    see screen shot
  1. etransmit
    By param.cambow in forum AutoCAD General
    Last Post: 2010-08-31, 06:41 AM
  2. ETransmit
    By Tommybluegrass in forum AutoCAD Tips & Tricks
    Last Post: 2007-12-17, 02:01 PM
  3. etransmit
    By dzatto in forum ACA General
    Last Post: 2007-10-18, 05:19 PM
  4. ETransmit - What do you do...
    By kschultz in forum AutoCAD General
    Last Post: 2006-01-25, 02:37 PM
  5. etransmit
    By cds in forum ACA General
    Last Post: 2004-10-08, 11:22 AM
