Results 1 to 9 of 9
Thread: trellis with a vine
    100 Club J-G's Avatar
    2003-04
    181
    Default
    I have a rendering I would like to do with a trellis and some sort of vine growing up it. I haven't spent any time as of yet on rendering, but now I need to. What would be the best way to do this? Should I render the scene and then try to add the foliage in Photoshop, or are there families that someone knows of?
    Thank you for any help...I am also looking for a wider selection of stucco and roof colors, are there better resources?
    2003-05
    5,153
    Default Re: trellis with a vine
    Check out this topic on Ivy
    Accurender may also have something.
    If that doesn't work, there is always $RPC.
    Re stucco and roof colurs.... try Accurender's site ( Home page link from Zoog ) and RUGI.
    Other than that there are many sites for free textures. Some of the links are listed in Rendering topics.
    Bruce Gow.
    Karel*CAD. Application Specialist..
    Architect.
    Revitalize. Blog
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    and here is a post on making a parametric lattice which you may wish to use as a component in your trellis. Alternately make a solid trellis with a see through material. It will render correctly and show as a solid item in other views but might be quicker if that is an acceptable route.
    Pete
    2003-04
    181
    thanks for the help
    2012-02
    Vancouver
    15
    I am similarly trying to create growing vines on a wall but the two links arent leading me anywhere helpful. Might they be refreshed?
    2009-03
    Lyon, France
    401
    I advise you to add them on your rendering with photoshop
    For your elevations, you can easily create light png files and insert them on revit.
    Antoine Petitdemange
    AXE Architecture - Lyon
    http://www.axearchilyon.fr
    I could stop if I wanted to rbcameron1's Avatar
    2008-09
    Nebraska & Iowa
    378
    Unless you export to 3dsMax and acquire some decent vines off turbosquid or something, best to stick with photoshop on this one. OR create the best ever decal of what you want and render it in Revit as an decal image in your view!
    RB Cameron, AIA, LEED AP, EDAC
    BIM Coordinator - VDC Coordinator - Visualization Artist
    Download Healthcare Revit+3dsMax Models
    Download Revit+3dsMax Models
    2015-08
    84
    Quote Originally Posted by rbcameron1 View Post
    it's actually fairly doable now with adaptive components. Create a section of vine with 'x' number of leaves and a 3 point selection to handle arcs/angles. It will be heavy as all can be if done realistically, and not really recommended, but it can be done.
    2008-09
    Nebraska & Iowa
    378
    Yeah, I have a very intense model that uses some of those adaptive curtain wall spider connections. I even have a high-end computer and it drags and drags when any decent components are used. Granted, it can be controlled through visibility settings but still....I'd like Revit to be able to handle geometry better. Strange since I put that file into 3dsMax and there is essentially no drag at all.
  1. Trellis
    By konetarchitecture in forum Revit Architecture - General
    Last Post: 2011-05-27, 05:24 PM
  2. Trellis
    By rshank3499 in forum ACA General
    Last Post: 2008-07-21, 06:52 PM
  3. Trellis help
    By shamshirha in forum Revit Architecture - General
    Last Post: 2007-09-13, 04:10 PM
  4. 3ds Max - Crawling Vine
    By dellis in forum DV - Gallery
    Last Post: 2007-04-04, 07:31 PM
  5. Trellis
    By mwagenbach in forum Revit Architecture - General
    Last Post: 2006-04-25, 09:25 PM
