I have not found to many threads but it seems that there is no way to export object styles, correct? I am in the process of creating office standards and found the only way to really make it work is to start a project. Now that i am getting things the way that i want, i need to transfer those object styles over to the template that i already made.
Is the only way to transfer these styles to save the project as a template?
Also while i am takling about object style is would like someone to clear something up. if you look at the door objects (or any) there is a projection and a cut linewiehgt. you can then expand doors to have various other componants. does the projection mean every other time that it is not cut (ie plan, perspective, elevation)?
THanks
Justin
