Thread: Array with Variable Spacing
    All AUGI, all the time ajayholland's Avatar
    2003-04
    Sunny Southern California
    505
    Default Array with Variable Spacing
    I would like the spacing of the vertical battens in this wall-based family to vary by formula based on the overall length of the array.
    I’m close to a solution. Someone enlighten me, please.
    ~AJH
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    Question Re: Array with Variable Spacing
    I looked at your family. It appears to be doing what you want it to. Could you elaborate a little more on what you want it to do?
  1. Parametric Array spacing control
    By DoTheBIM in forum Revit Architecture - Families
    Last Post: 2018-06-13, 05:21 PM
  2. 2013: Array with progressive rotation and spacing
    By libre in forum Revit Architecture - Families
    Last Post: 2013-04-05, 04:56 PM
  3. Text-For-Each line spacing variable?
    By clj in forum AutoCAD Civil 3D - Pipes
    Last Post: 2008-01-30, 07:36 PM
  4. Parametric Array spacing control
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2007-04-19, 12:56 AM
  5. Spacing parameter in a nested array
    By J. Grouchy in forum Revit Architecture - Families
    Last Post: 2005-03-07, 03:28 AM
