gpope
Have you ever needed to know what the viewport boundary is in model space, so you know if you were going outside what the viewport would show?
Here is a simple trick to use if you have express tools installed on your system.
In paperspace, draw a rectangle over your viewport.
In the express pull down menu, go to Layout Tools=>Change Space.
OR
Type CHSPACE at the command line.
Select the rectangle you have drawn.
Follow the rest of the prompts
Now you will have a boundary in model space that matches the boundary of your viewport.
