Thread: Can't keep wall and floor joined
    2005-04
    16
    Unhappy Can't keep wall and floor joined
    I am trying to attach top of a wall to the series of double sloping (triangular ) floor slabs above.
    Wall does attach to a few, but for most of them I get the error message:
    "Can't keep wall and floor joined". How do I fix this?
    2003-05
    5,153
    Default Re: Can't keep wall and floor joined
    Might be best to post a purged file with the sample condition so we can take a look.
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Check to make sure the wall edges are completely under the floor to be attached. It doesn't matter if the wall's end point extends beyond the floor but the actual depth of the wall needs to be contained in the floor in order to attach.
    Also, i assume your floor has either been done with an in-place or external family. In this case check to make sure the floor isn't overlapping itself anywhere (multiple levels) as this will confuse the wall and not know which part of the floor to join to.
    HTH.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
  1. 2010: Can't keep wall and floor joined
    By Giorgos82 in forum Revit Structure - General
    Last Post: 2013-08-17, 07:54 PM
  2. 2012: How to extend top or base of a wall layer when the wall ends wrapped and not joined to other wall?
    By architekz.188213 in forum Revit Architecture - General
    Last Post: 2013-01-24, 08:46 AM
  3. Replies: 0
    Last Post: 2013-01-15, 10:12 PM
  4. "Can't keep wall and floor joined"
    By kate.morrical61357 in forum Revit Structure - General
    Last Post: 2008-02-07, 09:15 PM
  5. Can't keep wall and floor joined
    By overcaffeined1745 in forum Revit Architecture - General
    Last Post: 2003-06-17, 10:12 AM
