Thread: Problem with leader in Mechanical 2005
    2003-12
    The Hammer
    88
    Unhappy Problem with leader in Mechanical 2005
    When I select the leader command from the pull down menue or the shortcut button, I lose my cursor inside the drawing area. Is there a setting I need to change to get the cursor to show inside the drawing area?
    Thanks
    Brad
    2003-02
    2
    Default Re: Problem with leader in Mechanical 2005
    Brad,
    When I lost my cursor on the field of my drawing, I had to go to TOOLS-OPTIONS-DISPLAY tab. Select the Colors button & in the Windows Element field, select Layout tabs pointer and make sure if you have a black background, your pointer (cursor) is set to White. I was having a black cursor on a black background.
  1. Leader Text ACAD 10 Mechanical
    By bagdazian in forum AutoCAD General
    Last Post: 2010-02-26, 06:17 PM
  2. Using AutoCad 2005 Mechanical
    By frank.scharber in forum AutoCAD Mechanical - General
    Last Post: 2008-05-01, 03:40 PM
  3. AutoCAD Mechanical Wishlist AU 2005
    By jonathan.landeros in forum AutoCAD Mechanical - Wish List
    Last Post: 2005-11-22, 06:24 AM
  4. Mechanical Destop & Acad 2005 Together?
    By Cosmic Traveller in forum MDT - General
    Last Post: 2005-02-26, 06:33 PM
  5. Mechanical 2005?
    By chill in forum AutoCAD Mechanical - General
    Last Post: 2004-06-29, 03:08 PM
