Could some one explain , how could we make a vertically tapered wall.
larger at thee bottom and narrower at the top for example?
thanks
thanks
Is this a Revit question? You would make an Inplace family (Wall Category) and then you have a choice on using: sweep, blend, or extrude with void...
A maybe better way is to make a normal wall the maximum (or minimum) of the wall (either the with of the base or the top) and then create a void (if the wall's thickness is the maximum) or a solid (if the wall's thickness is the minimum)
http://forums.augi.com/showthread.ph...highlight=wall
The picture is missing from the second one, but the description may help.
thanks,
Yes it was a Revit Q;I will try it this weekend.....very helpful direction.............ask you guys more question later?!!!
Of course! That's why we're here!Originally Posted by afshin_samimi
If the tapering occurs in steps, you can use Stacked Wall types.
If you are just ending finish layers (i.e. extending a finish only up to a given height) you can unlock those layers in the wall type and adjust them in section to the appropriate height.
If the tapering is smooth (i.e. slanted or curving or 'bowed', then you would need to do as Luigi describes).
