Can you array an attribute in a dynamic block? I've tried, and obviously been unsuccessful, but I just started using dynamic blocks, so I might be missing something.
Thanks!
Thanks!
I had never thought of that? But did give it a try and it will not recognize a attribute for an array action. So no doesn't look like it works.
Darn. Well that severely limits a few of my blocks...
Thanks again,
Frank
Ya bummer. But something you could try to get your ARRAY of attributes is maybe make a nested block that has your attribute. Then hookup your array to the block. Then array as needed then simply explode your block down to multiple attributes? You loose the block of course but would save you from copying attributes all the time? Just a thought.
