Please see attached dwg. I cannot select any of the items in the file unless I use a "select all" and it's getting annoying. Anyone have any ideas?
Loyalty above all else except honor
For my honor is my life!
Just out of curiosity - right?Originally Posted by jmelanson
Select ALL and move by 0,0,-18.6126. You can now Select and Erase all but the text item.
Select ALL again and move by 0,0,84.9382. You can now Select and Erase the text item.
I think the block insertion points have, somehow, become entangled with the text insertion point although the text has a different Zvalue from the blocks.
List still shows the blocks but now with a Zvalue of 66.3256 but they can now be erased.
After this the file is empty.
How, why, who knows.
HTH
After I flattened everything to have a z value of zero, then it worked just fine.
Hi
Have a browse of the following threads (all three of them offer you a workable solution) -
Text entities not there.....
Quick select is not permitted in perspective view?
"Extruded entities"????
Have a good one, Mike
