When I use Etransmit and select the bind option for xrefs, it does not bind the xref. Does anyone know what causes this?
hmm, not sure what would help here... just a little background... which version are you on? can you post a screenshot of your etransmit settings? perhaps one of the xref dialog of one of the offending drawings also... hoping anything will trigger an answer (right now I'm personally stumped)Originally Posted by hostetterkl
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
HiOriginally Posted by hostetterkl
Just to carry-out an experiment, what happens if you take ETransmit out of the equation ie. Within the actual "Master" drawing file, Bind the Xref files?
Does that work?
Have a good one, Mike
Perhaps you have a circular reference?Originally Posted by hostetterkl
I'm able to bind the xrefs when I open the drawings manually.
Hi
Is it possible to post an example set that does not work with ETransmit.
What version of AutoCAD are you running?
