Results 1 to 8 of 8
Thread: Layer Filters...
    2005-05
    71
    Exclamation Layer Filters...
    Can anybody help me with a way to delete in masses layer filters. We are using Acad 2002 and evrytime I get a drawing from our civil engineer and other places it has hundreds of layer filters and it makes the file size huge. I fon't have the time to delete them one by one.
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Re: Layer Filters...
    See this post
    Hope this helps...
    All AUGI, all the time madcadder's Avatar
    Back in the Bay; Looking for work.
    979
    (defun c:lfd (/ dicts dict filtr)
      (vl-Load-Com)
      (vl-Catch-All-Apply
    	'(lambda ()
    	   (setq dicts (vla-GetExtensionDictionary
    	   (vla-Get-Layers
    		 (vla-Get-ActiveDocument (vlax-Get-Acad-Object))
    	   (vlax-for dict dicts
      (if (and (= (vla-get-name dict) "ACAD_LAYERFILTERS")
    	(> (vla-get-count dict) 0)
    	(progn (vlax-for filtr dict (vla-delete filtr)))
      (princ)
    2005-02
    67
    I had a similar question the other day and through the responses found the above mentioned routine and it works great.
    I deleted over 19,000 layer filters from some of our drawings. My question is where the heck did they all come from. We don't use any outside sources or any consultant drawings, so how to they get made in the first place??
    2005-05
    71
    thanks for the link but how do I get it to run?
    2005-05
    71
    Talking Re: Layer Filters...
    nevermind i got it thanks for your guys help.
    I could stop if I wanted to LanceMcHatton's Avatar
    2002-04
    Las Vegas, NV, USA
    287
    Quote Originally Posted by tflaherty
    Anyone can make a layer filter and it sounds like maybe some of your coworkers have. Also, even though you don't use "outside sources", some of your coworkers may be using drawings they have from other offices they have worked at. Furthermore, old drawings that you might re-use may have filters, too. Every time you insert or xref a drawing, they follow and stick like glue.
    I'd like to offer some advice if I may. I don't know how my lisp compares to the ones in this thread, but I have changed my layer button (on a toolbar) to execute the DeleteLayerFilters lisp and THEN execute the layer command. That way, I never have to think about them or see them. They're just GONE. If everyone in your office does the same thing, you shouldn't have any more filter problems.
    Unless, of course, you actually USE layer filters, then you might be out of luck. Perhaps the lisp can be changed to only delete layer filters that don't have a certain prefix. For example, my company is G.C. Wallace, Inc. Any layer filters we use could have a prefix of GCW<filtername> so the list could delete everything but GCW*. I don't know, just a thought.
    Lance McHatton
    AutoCAD Architecture 2008
    Windows Vista
    I swear, I did not dado that rabbet.
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,260
    Quote Originally Posted by LMcHatton
    just as a matter of trivia, this issue was addressed in 2006
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
  1. Layer Filters
    By shelley.rutmanis in forum AutoCAD LT - General
    Last Post: 2011-10-10, 12:50 PM
  2. layer filters
    By richardronan in forum AutoCAD General
    Last Post: 2009-12-10, 02:28 PM
  3. Layer filters - again.
    By jaberwok in forum AutoCAD Tips & Tricks
    Last Post: 2008-11-27, 10:32 AM
  4. Layer Filters
    By harry.77503 in forum AutoCAD General
    Last Post: 2005-07-27, 04:32 PM
  5. Layer filters, anyone?
    By gbrowne in forum AutoCAD LT - General
    Last Post: 2004-07-20, 07:15 PM
