Results 1 to 9 of 9
Thread: Crash while Printing EVERY TIME!
    Active Member cstarr's Avatar
    2005-02
    65
    Default Crash while Printing EVERY TIME!
    Has anyone ever encountered this (see image attached)? Everytime I try to print exterior elevations, I get this error and the Revit crashes. At first I thought it was a Linework tool issue, it's not. Just started yesterday.
    Aussie Revit Moderator Mr Spot's Avatar
    2004-05
    Brisbane
    1,115
    Default Re: Crash while Printing EVERY TIME!
    Try fiddling with your open GL and overlay planes settings or update your display driver.
    Chris Price
    Co-Founder/BIM Manager/Product Designer
    Xrev Pty Ltd
    Revit Rants BLOG
    All AUGI, all the time BillyGrey's Avatar
    2004-04
    in a calm assertive state
    638
    Also, do you have the latest build? It might also help if you supply some details regarding plotter model, etc.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    we have certain views that do this and there is no fix i know of. I have to print to pdf. First try turning off your hardware acceleration and open gl and overlays. If that doesn't do it. you have to print to pdf. Please send it in, this has been a problem for me for years. It only rears its ugly head occassionally. We've narrowed it down to dwg imports in some cases, but we can't get rid of those.
    Scott D. Brown, AIA
    BECK
    2001-12
    Irvine, CA
    7,567
    Quote Originally Posted by sbrown
    ...We've narrowed it down to dwg imports in some cases, but we can't get rid of those...
    In some cases dwgs that were visible were actual plan views but visible in the elevation as a "line". Turning them off made a difference on a couple occasions that I can recall.
    Autodesk Revit Developer
    2004-02
    Waltham
    468
    The fix is to send the file to revitsupport@autodesk.com.
    2005-02
    65
    Turned off all dwg in the views, turned off open GL and overlay, and it still crashed...
    hmmmmm
    2004-04
    638
    cstarr, please do as Fedor suggests, your head won't hurt from banging it on the wall so much. Also, whenever I send in a file, I always call tech support first, and get the ball rolling.
    Otherwise, printing to PDF is an option like Scott says...
    2003-05
    Coast to Coast
    4,440
    I did send my files to revit the case number is 1-109037120. If you want to check into, the status is still OPEN. We had narrowed it down to one dwg, but it happens on other views that have no dwgs turned on, so it maybe just having a bad dwg in the project causes problems.
    Scott D. Brown, AIA
    BECK
  1. Replies: 1
    Last Post: 2017-03-06, 08:56 PM
  2. I crash every time I try to create a new part inside an Assembly
    By d.m.polsky in forum Inventor - General
    Last Post: 2012-10-05, 01:41 PM
  3. Printing Graphic Col Schedule cause Revit to crash
    By JH75 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-10-24, 03:53 AM
  4. Autocad crash when printing - solved
    By terryh in forum CAD Management - General
    Last Post: 2008-04-07, 03:05 AM
  5. MDT Crash Every time..
    By rosterreicher in forum MDT - General
    Last Post: 2004-10-08, 07:55 PM
