Thread: Adding Baluster family to railing editor
    2003-12
    Southern Ontario
    58
    Default
    2 questions
    See attached jpeg.
    1 - Does anybody have a baluster family that could perhaps make my rings or how would one be made. The rings are 4" Dia x 1/2" sq crs.
    2 - How does one add a family to the baluster editor drop down box when you are in the "edit baluster placement window."
    2003-04
    Irvine, CA
    6,773
    Default Re: Adding Baluster family to railing editor
    I believe you need to find a increment where the rings and bars pattern repeats...for example 5 bars for each 3 circles.
    Build a baluster family using this pattern and import into your project. Then it will be available to your railing style when editing.
    I think you'll be constrained to placing railings that are nearly the exact multiple of the pattern unless you use the "fit" option, then they'll adjust a bit, but look funny if you are very far off of a multiple of the pattern repeat.
    Check out the sample balusters in the BALUSTER folder...there is a panel and four attachment components in one that is the general concept except you subtitute the pieces you need instead.
  1. Railing -Baluster Cleanup
    By psmith880742 in forum Revit Architecture - General
    Last Post: 2011-11-23, 06:53 PM
  2. Railing baluster problem
    By Carlos GT in forum Revit Architecture - General
    Last Post: 2007-12-13, 01:35 PM
  3. Railing, baluster problem.
    By space_spikes in forum Revit Architecture - General
    Last Post: 2007-11-21, 12:17 PM
  4. Railing and Baluster frustration!
    By Shaun v Rooyen in forum Revit Architecture - General
    Last Post: 2006-02-08, 03:59 PM
  5. Railing Baluster Locations
    By DanielleAnderson in forum Revit Architecture - General
    Last Post: 2004-09-20, 08:43 PM
