Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Sloped wall
    2002-07
    15
    Default Sloped wall
    Hi,
    I wonder how to create a sloped wall in elevation?
    Thank you,
    Florin
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: Sloped wall
    One way is creating an InPlace Component, but then you will need to cut openings into it and jump some hurdles to add doors and windows.
    Another way is to create a mass which has your desired slope, then create a curtain system. With this curtain system(make sure it has no grids), just then select the panel (keep hitting TAB until the panel is selected) turn it into a solid panel. Modify the solid panel to have the properties you want with the thickness and offset. Now, to have windows and doors treat it like you would a normal curtain wall (creating grids, then modifying the panel to be what you want: glazing, solid, doors, etc)
    Currently, walls sloped in section (or popularly called tapered walls) are not supported.
    I hope any of this helps.
    All AUGI, all the time ejburrell67787's Avatar
    2004-03
    Hereford, UK
    820
    Quote Originally Posted by florin_balcu
    Hi,
    Thank you,
    Florin
    Also possible to make it as a stteply pitched roof component... although this obviously results in (roof based) openings behaving as they would in roof...
    ...depends on what you want to achieve - post an image of some kind if you still need more pointers...
    Elrond Burrell, Architect
    [Connect with me on LinkedIn or Twitter]
    "The best time to plant a tree was 20 years ago. The second best time is now."
    - Chinese Proverb
    100 Club daniel.hurtubise70031's Avatar
    2004-06
    Montreal, Canada
    153
    How about just editing the profile of that wall ?
    2015-11
    Royal oak, Michigan
    1,513
    Red face Re: Sloped wall
    Quote Originally Posted by Daniel Hurtubise
    Daniel, you are onto something!!! I now think he just meant to slope the wall in elevation...not section.
    This would mean I am sounding like an old gong!!!!
    I would give you some rep points for clearly reading the guy's post....something I should have done before posting an answer to a different question...
    2004-06
    Montreal, Canada
    153
    Could have been worst... could have tell the guy to go fill with water, then add coffee.
    2004-03
    Hereford, UK
    820
    Quote Originally Posted by luigi
    Daniel, you are onto something!!! I now think he just meant to slope the wall in elevation...not section..
    Sounds too easy hey Luigi!
    maybe Florin will clarify, but I didn't think editing the profile of the wall is what was meant either... but then again maybe it was...?
    - Chinese Proverb
    2002-07
    15
    Hi,
    Sorry.
    I mean sloped wall in the section view not in elevation (I know I can edit the profile)
    Thank you all,
    Florin
    2004-06
    Montreal, Canada
    153
    How about edit cut geometry then ?
    AUGI Addict PeterJ's Avatar
    2003-04
    London, UK
    1,948
    That's not a 3D solution though
  1. Sloped wall
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2009-03-03, 03:38 PM
  2. Add a Sloped wall?
    By gustav.ling in forum Revit Architecture - General
    Last Post: 2008-12-02, 12:27 PM
  3. Reveals on a sloped wall
    By sungze in forum Revit Architecture - General
    Last Post: 2008-07-24, 03:02 AM
  4. sloped wall
    By brooke.c in forum Revit Architecture - General
    Last Post: 2007-03-07, 06:27 PM
  5. sloped wall
    By iffans in forum Revit Architecture - Families
    Last Post: 2004-10-14, 03:58 PM
