The way you do this is you create *two* schedules, one's the Door Schedule (a normal Door Schedule), and the other's the Hardware Schedule (a Door Schedule set to be a 'Key Schedule').
First, generate the Key Schedule by picking View -> New -> Schedule, Pick 'Doors' as the Category, name it 'Door Hardware', and then pick 'Schedule Keys' instead of the default 'Schedule Building Components', change the name of the Key from 'Door Key' to 'Hardware Code' (that slot below the radio button) & hit OK.
Now you'll have a Schedule with 'Key Name' as the only field scheduled. Add new parameters for each bit of hardware you want to track, like 'Comments' 'Closer' 'Latchset' and such, setting them as yes/no or text parameters so you can fill them out as desired. Or better yet, use some presetup Shared Parameters. Set how you want the Schedule to sort itself & it's appearance and such, and hit OK.
You'll now have a blank Hardware Schedule. On the Options Bar next to 'Rows:' you'll see a button that says 'New'. Press this to add new rows to your Schedule, one for each Hardware Group. Fill these out, and edit the key names(s) to be something like 'A', 'B', 'C'; for these are your Hardware Groups.
OK, so, finally, go back to (or make) a normal Door Schedule, and there will be fields available to you (all of the ones from the Hardware Schedule) as well as a new one 'Hardware Code'. Now add these Fields to your Schedule and organize them the way you want & hit OK.
Now, if you pick on 'Hardware Code' on your Door Schedule, you're presented with a little drop-down list of your Hardware Groups you defined a little while ago. Set it to A, and all the other Parameters ('Closer' 'latchset' et. all) automatically set themsevels to match Group A's settings from the Hardware Schedule. Same for B, C, whatever. Also, now, if you go back and edit the Hardware Schedule, and say, change Group A to no longer have a Closer, it will change everywhere. This is also a huge help for Head/Sill/Jamb details, for not to twist your head, but you can have multiple Key Schedules within a single normal Schedule...
Hope this helps.
