Results 1 to 7 of 7
Thread: Lineweights plotting light
    2003-11
    258
    Exclamation Lineweights plotting light
    Ok so I am at a loss.
    When I plot this one drawing it plots incorrectly by plotting too light. So I have created a new ctb and pushed up the weights and that did not help. It plotted exactly the same. Is there a setting in the drawing that I need to disable or enable that make the dwg plot by the ctb?
    -Russ
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Re: Lineweights plotting light
    what version are you running?
    w/ 2005...under plot options (to the right of the plot dialog box) there is a check box for plot with plot styles.....you might have the "plot object linewieghts" checked???
    2003-11
    258
    it is grayed out and unchecked
    and i have 2005
    2003-12
    Palm Harbor, FL
    537
    you want it to be checked if you want to use the ctb file....see attached screen shot....
    2003-11
    258
    Talking Re: Lineweights plotting light
    sorry you were right i took a closer look
    and that was exactly it
    i unchecked"plot with plot styles" unchecked the "plot object lineweights"
    and then re checked "plot with plot styles"
    and it worked but now the "plot object lineweights" is checked and grayed out
    so anyways thanks for keeping me from going bald
    -Russ
    2005-06
    7
    Angry Re: Lineweights plotting light
    hey im having the same problem and i just tried that. it didn't work my lighter lines are still coming out spotty
    150700
    3,439
    Quote Originally Posted by CHRISR.88946
    Chris,
    This issue is being addressed in your post in the AutoCAD LT Forum. If you would like, I can move the thread to the plotting forum, but I ask that you please refrain from posting the same question in more than one place.
    Below comes from the AUGI Forum Guidelines - Forum Don'ts -
    <snip>
    Do not post the same question to more than one Forum at a time. The term for this is "Cross-Forum Posting" which can be quite confusing and will complicate the Forum process. All but one of the posts will be deleted by the moderators.
    </snip>
    Thanks for your understanding,
  1. Lineweights for Plotting
    By Sparky in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-09-27, 05:10 AM
  2. plotting lineweights
    By vanderloo5 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-06-22, 07:25 PM
  3. plotted lineweights way too light!!!
    By rami1 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2009-03-05, 06:13 AM
  4. Lineweights in Floating Viewports Plot light...
    By jeff.garr in forum AutoCAD Plotting
    Last Post: 2007-01-04, 02:53 PM
  5. Lineweights change when plotting
    By JOHN47910 in forum AutoCAD Plotting
    Last Post: 2004-12-03, 02:25 PM
