Thread: AutoCAD 2004 - Install Express Tools
    2005-02
    67
    Question AutoCAD 2004 - Install Express Tools
    I thought I read someplace awhle back that AutoDesk made the Express Tools a standard part of AutoCAD. I'm using ACAD 2004 and can't find them. Is it a still a seperate install? Or are they just spread out all over the place?
    Thanks
    2004-10
    Yorkshire, UK
    398
    Default Re: AutoCAD 2004 - Install Express Tools
    Quote Originally Posted by tflaherty
    Thanks
    Put in your install CD for AutoCAD 2004, and there will be an option to install express tools on the Autorun screen.
    They are installed in a Full version of AutoCAD 2006 but not earlier versions
    2005-02
    67
    Did that, the option isn't there. I read the Help file and it said it should be listed under Step 5 Suplemental Tools, but it's not there on my install screen. Are they still the same as from 2002. I've got those, will they work in 2004?
    0,0,0 The Origin
    8,029
    The 2002 ETools will not work with A2004. But the 2004 ETools definitely should be on your CD.
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2004-10
    Tampa
    52
    The Express Tools wont be found if you are using A2004LT. It must be a full version.
    I have all the answers,
    Now if I could remember where I put them.........
  1. Express Tools not working in AutoCAD 2004
    By bpurdie in forum AutoCAD General
    Last Post: 2006-08-09, 11:17 PM
  2. Install Express Tools with AutoCAD 2005
    By CadDog in forum AutoCAD General
    Last Post: 2006-03-22, 07:45 PM
  3. AutoCAD 2004 - Lost Express Tools
    By ATait in forum AutoCAD General
    Last Post: 2005-11-23, 09:17 AM
  4. Express Tools don't stay loaded in AutoCAD 2004
    By Grumpy in forum AutoCAD General
    Last Post: 2004-08-17, 05:18 PM
  5. Missing Express Tools in AutoCAD 2004
    By bnia in forum AutoCAD General
    Last Post: 2004-07-06, 11:26 AM
