Results 1 to 7 of 7
Thread: Curve Label problems
    2005-05
    15
    Default Curve Label problems
    All of my curve labels seem to be bylayer on the screen but when I plot preview it's as if they're taking on layer "0" characteristics...ie, they're plotting bold using color 7 but they're displaying color 191. All of my parcel curve label settings are set to "bylayer". Any ideas???
    Civil Engineering Moderator MHultgren's Avatar
    Clyde, NC - USA
    1,384
    Default Re: Curve Label problems
    How do you have your Styles set up. Bylayer or Hard coded colors?
    Mark Hultgren
    Just a Lurker
    http://www.MKW-Ind.com
    Blog
    Socializing??
    2005-05
    15
    All my styles are set to bylayer
    2002-06
    95
    Is it possible that you've got two sets of labels in the same place? Sometimes things don't display in correct plotting order, although send to back and regen should show it up straight away. But I don't think you can send one label to back as there's no way to select just the label.
    Hope that makes some sense.
    100 Club MMccall.83699's Avatar
    2005-03
    a little off center
    138
    Quote Originally Posted by b.mossman
    What exactly do you mean by "bold" Fatter line weight? Bold/wrong font? Black vs Screened?
    And, is your line weight controlled by layer or color?
    Check your label style for line width settings that may be overriding your intended line weight, and be sure to bore all the way to the bottom style settings. (into the text formatting)
    2005-05
    15
    Colors 1-10 are controlled by color;
    colors 11-255 are controlled by layer.
    I have a layer called S3-P-CRV_LBL; color 191; lineweight=default. This layer is specified as the default layer in my curve label style. When I plot, the curve labels are real thick as if they are taking on layer "0" properties (color 7...which is our boldest lineweight). I changed layer "0" to red (our lightest pen weight), and the curve labels still displayed color 191 in the dwg editor, but when plotted they took on pen 1 lineweight.
    It has to be something in the style settings because I have separate layer for my line labels that also uses color 191 & they come out fine.
    2005-05
    15
    I just figured it out...
    Under label Style Composer--> allow curved text=false, then it previews correctly by taking on the appropriate layer properties. When allow curved text=true, then the label in the preview turns to color 7 which is our boldest lineweight.
    Thanks for your help!
  1. Annotative Label Curve?
    By ekolto in forum AMEP General
    Last Post: 2008-09-26, 09:45 PM
  2. Label curve fractions
    Last Post: 2008-07-02, 08:38 PM
  3. Curve Label Problems
    By .T. in forum AutoCAD Civil 3D - General
    Last Post: 2007-11-27, 04:37 PM
  4. Grade label around curve.
    By jbbarrus in forum AutoCAD Civil 3D - Grading
    Last Post: 2007-08-23, 06:31 PM
  5. Label Curve Styles
    By rcroke in forum AMEP General
    Last Post: 2007-05-29, 10:26 AM
