My base maps are connected to an SQL DB via Link Templates. I created a new table in SQL using data from an existing table. The linked opjects in Map were exported as .shp files with the old DB info. I then created a Link Template to the new table and imported the .shp file using the option to create data in a DB table, but checked Generate Links Only. When the objects are imported everything works perfectly with the new Link Template. I save the drawing and reopen, the Link Template is fine and pulls up the associated table, but the Link Templates no longer exist on the objects.
Thank you for your help,
Jeremiah
