Results 1 to 10 of 14
Thread: Revit with 64 bits technology
    2005-05
    Santiago - Chile
    18
    Default Revit with 64 bits technology
    hi,
    Who knows something about revit 8 performance with 64 bits AMD processors??
    thanks
    Milton
    I could stop if I wanted to rodneyf's Avatar
    2003-05
    Charlotte, NC
    251
    Default Re: Revit with 64 bits technology
    We are rolling along without any hiccups on 9 machines with AMD Athlon64 4000+ processors and will be getting more soon.
    2001-12
    Irvine, CA
    7,567
    Quote Originally Posted by rodneyf
    ...rolling along without any hiccups on 9 machines...
    Any comments on performance improvement?
    AUGI Addict iru69's Avatar
    2004-10
    usa
    1,591
    Quote Originally Posted by mvicentelo
    Regarding the 64 bit part, check out this thread (unfortunately it gets way off topic in the middle, but the short answer is that unless you're using over 3GB-4GB ram, 64 bit isn't going to be any better than 32 bit):
    http://forums.augi.com/showthread.ph...ighlight=64bit
    If you're wondering, there's no reason not to go with the Athlon64...
    I could stop if I wanted to Damo's Avatar
    2004-05
    London, UK
    326
    Performance increases on 64bit Athlon (or Intel for that matter) won’t be seen until there are 64bit programmes, and Revit Building 8 isn’t 64bit.
    You will also need a 64bit operating system. Initially 64bit versions of Windows will be XP Professional & Windows Server 2003 (Tablet PC and Media Centre will follow).
    Using Release Candidate 1 of Windows XP Pro 64bit, a recent report in PCW said there was a greater performance increase in tests with Intel PCs over Athlon, as the Windows 64bit operating system makes better use of Intel CPU’s hyperthreading technology.
    Of interest to you, PCW said ‘The performance of 32bit programmes does not change appreciably under the 64bit operating system…. tests was almost identical to that on the 32bit platform’
    I suppose the only advantage of using 64bit hardware is that the system can address up to 128GB memory, as opposed to the current limit of 4GB with 32bit operating systems. So, if you have large files and 4GB memory isn’t enough then the extra memory you can have with a 64bit machine may give you some benefits, but not in performance terms.
    Autodesk Revit Developer
    2004-02
    Waltham
    468
    64 bits can in theory address 16 exobytes.
    But yes, right now it's like filling your old gas guzzler with premium...
    2003-05
    Charlotte, NC
    251
    Steve
    I know this much for sure ever since going to these machines I have yet to lock one up by that I mean the processor staying at 100% for more than a 2-6 seconds max. Hope that helps.
    2004-10
    27
    Steve
    How much RAM do you have in your machines?
    Thanks
    2003-05
    Charlotte, NC
    251
    We have 2 gigs in our machines. I should also note that when it does take the 6 seconds it is on a 4 story over 1 story of parking highly detailed condo building other than that it is smooth sailing.
    AUGI Addict hand471037's Avatar
    2003-05
    Oakland, California
    1,934
    Quote Originally Posted by FK
    Great analogy.
    However, just a quick note, you might be able to get more 'bang for your buck' with the AMD's. They are fast and capable, and can be cheaper than the Intels. So regardless of you not being able to use the 64-bit portion yet, it might be a better deal anyways. Check out Tom's Hardware or a simluar site for Benchmarks and then look at the prices of said systems and you'll see what I mean.
  1. XP PRO 64 BITS OU VISTA 64 BITS
    By batproj in forum 3ds Max - General
    Last Post: 2009-05-18, 05:28 PM
  2. Autodesk Annonce Revit e 64 bits (au US)
    By gravelin in forum Revit Architecture - General
    Last Post: 2008-10-01, 12:20 PM
  3. xp 64 bits para usar Revit
    By desarrollolatinos in forum Revit Architecture - General
    Last Post: 2008-08-29, 11:52 AM
  4. revit 64 bits
    By drophouse in forum Revit Architecture - General
    Last Post: 2008-04-24, 11:15 PM
  5. Revit with 64 bits technology
    By mvicentelo in forum Revit Architecture - General
    Last Post: 2005-06-08, 09:12 PM
