Thread: Revit 6 ODBC Export of Shared Parameters
    2004-01
    Charlotte, NC
    3
    Default
    In the docs for Revit 6 it indicates that you can now get shared parameters to export correctly through ODBC. We setup our families using shared parameters for all data attributes. We place the families and everything schedules fine within Revit. However when we export to ODBC using MS Access as the data source we do not see our shared parameters or associated data.
    The REVIT document I have says the following:
    Shared Parameters Export to ODBC
    “Shared Parameters added to a project as project parameters will be included in the database tables exported to ODBC. If loaded families also contain the same Shared Parameters, that data will be exported as well.”
    What the heck does this mean?
    1. We setup shared parameters first for all our families then did an export and we did not see the shared parameters arrive as expected in the database...
    2. After Re-reading the docs above, I went back to project settings and added matching Project Parameters based on the same Shared Parameters to the project and tried it again. Still no-go…
    What am I doing wrong here? Does anyone know how to get Shared Parameters data from single families out through ODBC with R6?
    I could stop if I wanted to Nic M.'s Avatar
    2001-11
    Antwerp, Belgium
    480
    Default Re: Revit 6 ODBC Export of Shared Parameters
    I'm also looking for this new feature but can't seem to find it.
    If I export to ODBC I don't get shared parameters
    From the "What’s New in Autodesk® Revit® 6.0" document
    Export to ODBC
    – Now exports Shared Parameters to ODBC sources
    – Allows exporting your own custom data out from the Revit model
    Can somebody confirm this as a feature and how it should be used
    or is this feature removed from the original release?
    I could stop if I wanted to David Conant's Avatar
    2003-05
    Milton MA
    286
    You must add the shared parameter as a project parameter assigned to a category for anything to show up in ODBC.
    You need to coordinate 2 activities:
    1. Add shared parameters to families if you want to assign type values to them before bringing them into a project. (If the shared parameters will only record information that is unique to each project, you can ignore this step since adding as a project parameter alone will suffice)
    2. Add the same shared parameter to your project using Settings|Project Parameters. Be sure to assign the shared parameter to the same categories as the families. This will push the shared parameter into every loaded family of the selected categories. Those with the shared parameter added in the family editor will remember the values assigned in the family editor. All other families will get the shared parameter with no values. Values can be assigned in the project as desired.
    Once this is done, the shared parater and its values will be present in the ODBC tables for all categories it was assigned to as a project parameter. Instances for which no value was assigned to a shared parameter will show a blank in the corresponding table field.
    2003-04
    London NW9
    377
    Just tried it and it worked fine for me
    Created a quick EXT parameter (ironmongery package type)
    Applied that to the door catagories
    Exported to Access Database
    and wam bam
    The shared parameter is in the door table within access
    Brilliant ! Revit
    2001-11
    Antwerp, Belgium
    480
    Thanks verry much David,
    I diden't find info on it in the help file.
    May I add that you need to create a new database to get the parameters.
    I made the mistake to export to an existing database and diden't get any parameters.
  1. 2014: favorite shared parameters in Revit MEP
    By mehdi.kardehi565550 in forum Revit MEP - General
    Last Post: 2014-03-04, 07:23 PM
  2. Revit 2010, Windows XP, ODBC Export error
    By LouisJ in forum Revit Architecture - General
    Last Post: 2009-07-08, 05:42 PM
  3. Can you export multiple Shared Parameters from a Project
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2008-10-15, 03:09 PM
  4. Revit Architecture ODBC Database Export Question
    By infotech.155807 in forum Revit - API
    Last Post: 2007-12-21, 01:32 PM
  5. Shared Parameters Not Exporting to ODBC
    By Duffy in forum Revit Architecture - General
    Last Post: 2007-09-25, 10:16 PM
