Results 1 to 10 of 16
Thread: Fillet and Chamfer
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    980
    Exclamation Fillet and Chamfer
    What would cause the fillet and chamfer work with wall? When I would want fillet 2 walls. The wall would not be noticed.
    thank you,
    Brad
    2002-09
    Madison, WI
    5,688
    Default Re: Fillet and Chamfer
    Brad,
    I'm guessing you made this post in one heck of a hurry. Can you please clarify what you mean.
    Thanks
    100 Club cholmes's Avatar
    2003-02
    Omaha, NE
    198
    Which version of ADT are you using? I know in 3.3 in order to fillet walls, you had to use a special command "AECFillet"
    In newer versions you dont need this, you can just use the regular fillet command. (I think ADT actually redefines the fillet command to use this command)
    2003-04
    Bethlehem, PA
    980
    Quote Originally Posted by david_peterson
    Brad,
    Thanks
    I am sorry for not explaining myself more clearly. When I try to fillet 2 walls together. The walls will not be recognize by the fillet command.
    2002-09
    Madison, WI
    5,688
    In 2005 it works.
    The only thing that might make a difference is making sure you select the correct side of the wall.
    If a wall is draw left, I think you may need to pick the left side of the wall.
    If you still can't fillet the wall together, check your baseline elevation.
    What type of message do you get when you try to fillet the walls together?
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Quote Originally Posted by BCrouse
    Another possibility is that you have two walls on top of each other or you have lines on top of your walls & you are picking a wall on one side & a line on the other.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2003-04
    Bethlehem, PA
    980
    In 2005 it works.
    Here is the message that I get when I try to fillet two wall. (Fillet requires 2 lines, arcs, or circles.)
    2002-09
    Madison, WI
    5,688
    Well,
    If you checked everything else listed in this post and you are still getting this message, I'm at a loss.
    Can you post a copy of said file? Or is this in every file you have?
    If I can re-produce the error, I'll know it's a file issue rather than an install/ADT type issue.
    Are you using 2005?
    2003-02
    Omaha, NE
    198
    It looks like to me it is using just the standard Autocad fillet command. Try Aecfillet.
    Like I said, in later versions you shouldn't have to do this, but maybe you have a profile that is loading standard autocad commands, instead of the ADT ones. Or you are using and older version of ADT. Which version are you using?
    2003-04
    Bethlehem, PA
    980
    Quote Originally Posted by cholmes
    I am using ADT2005
  1. 2014: How do I fillet, chamfer, and dimension in isometric?
    By Vagulus in forum AutoCAD General
    Last Post: 2013-08-30, 04:45 PM
  2. 3d fillet / chamfer tool
    Last Post: 2012-07-16, 04:58 PM
  3. Fillet and Chamfer!
    By rsmannino in forum Revit Architecture - Wish List
    Last Post: 2006-12-08, 12:50 AM
  4. Crossing window for fillet and chamfer
    Last Post: 2006-03-13, 01:26 AM
