Results 1 to 10 of 10
Thread: Cookie cutter trim
    2004-10
    22
    Unhappy Cookie cutter trim
    Please can we have cookie cutter trim back? Thanks.
    100 Club JeremiahM's Avatar
    Colorado Springs, CO
    186
    Default Re: Cookie cutter trim
    Does Map>> Tools>> Boundary Trim do what you are looking for?
    Jeremiah
    2004-10
    22
    No, it doesn't. (Thank goodness for the Undo command!!!)
    Cookie cutter just trims the entities which crosses the selection polygon;
    Boundary Trim removes every entity which isn't in (or outside of) the selection polygon.
    186
    How about the FENCE option in trim.
    Start TRIM>> Select the items you want for TRIM boundaries and enter>> Type F enter
    Let me know,
    Jeremiah
    I could stop if I wanted to Andy.88917's Avatar
    2005-06
    Midland, Texas
    230
    The EXTRIM command works great for me still.
    Active Member Mike hacker's Avatar
    London
    64
    EXTRIM is ok, but it doesn't delete all the entities that don't cross the area you are trimming to. Or am i dreaming ???
    Used to find it very useful when trimming to a small area in a thumping great big survey drawing.
    100 Club tlewald's Avatar
    2003-01
    USA
    144
    Red face Re: Cookie cutter trim
    EXTRIM should definitely do the trick.
    lots of options too
    Member felix.81253's Avatar
    2005-01
    San Francisco
    27
    Extrim is fine - alone, in Autocad 2005 I somewhat managed to
    create my own shortcut...
    In 2006 when opening "cui"-"Command List"-Express commands"-
    a lot of Express Commands are shown, "Extrim" is missing.
    Are all or just some of the Express commands Lisp routines?
    "Extrim" is identified as such in the Express tools "help" file...
    Does this explain anything?
    To make it short: any idea how I can avoid typing "Extrim" in the command line all the
    time? Did I miss a fanciful Autodesk tool that renders "Extrim" obsolete?
    thanks,
    Felix
    2003-01
    USA
    144
    Wink Re: Cookie cutter trim
    Quote Originally Posted by felix.81253
    Felix
    edit the acad.pgp file to make it whatever you want.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,665
    Quote Originally Posted by felix.81253 View Post
    About half the rest are ARX.
    It probably helps. The lisp routine will probably still work in 2010, an ARX would not. Save a copy of the lisp in case it's not included in the future.
    To make it short: any idea how I can avoid typing "Extrim" in the command line all the time?
    Add it to a custom CUI.
    I've added it to my custom toolbar using the origional EXTRIM.bmp attached. In case anyone wants it.
    No. At least they didn't take it away, they just left it off the menu.
  1. Viewport cookie cutter
    Last Post: 2015-06-18, 11:39 AM
  2. cookie cutter trim
    By bapho in forum AutoCAD General
    Last Post: 2009-05-14, 07:11 AM
  3. Cookie Cutter Trim
    By andy.manninen in forum AutoCAD Tips & Tricks
    Last Post: 2008-02-28, 03:24 PM
  4. Express Tools - Cookie Cutter Trim
    By eleonard in forum AutoCAD General
    Last Post: 2005-11-16, 10:21 AM
  5. Cookie Cutter Trim
    By BCrouse in forum AutoCAD General
    Last Post: 2005-01-27, 11:16 PM
