Hi, I have read through several of the numerous Xref related threads but I have not found any that match my issue. I have two drawings that are Xref'd to each other (aka, Circular Reference). When I make changes to either of them and then switch to the other drawing and reload the Xref'd drawing, it does not update the Xref. I have to either detach and reattach the Xref or go into Options>Open and Save and clear the check box in the Retain changes to Xref layers variable (which I need on because I am isolating certain layers and want them saved in that configuration). This is probably just a rookie mistake due to the Circular Reference I am using but is there any way around this?
