Hi there,
I am still using 5.1; however, I have both read and been told the following.
In order to select all similar objects, simply select one, and click on "Filter". Once that is complete, it should select all similar objects throughout the model in order to modify an instance property. (ie: click on a 3068 wood door and all 3068 wood doors would be selected/highlighted.)
I have not been successfull with this. All I get is the dialog box showing the object's catagory checkmarked. If I click "ok", nothing happens.
I am attempting to modify a door instance property for just one door type used throughout the project. Specifacally, changing a typical office 3068 door from a wood panel to a glass panel. (instance property) I have noticed that if you change a type property, such as a ht. or width after selecting "edit", it does automatically change all similar doors throughout.
I must really be blonde, but, this should be an easy operation.
Thanks in advance
Steven Shell, Architect
Tucson, AZ
