Thread: Printing with Revit PDF Writer 4.2
    2005-04
    Saintlouis Missouri
    529
    Default Printing with Revit PDF Writer 4.2
    I have my first project close to complete and printed out a set. The problem I noticed after the fact is that the sheets printed smaller than it was supposed to. I am using a 24x36 titleblock but it scales down to have offsets. This is what I have been doing: Print-Setup-Paper- Arch D 24"x36".I have tried using center on paper placement as well as offset from corner. I also am sending the files to a print service using Oce and ghost script but I do not think that is the problem. I am at a loss. I even got a titleblock from someone else, but that did not work as well. I need some guidance.....I have attached the pdf.file to show what is doing. The paper shows to be 24x36 but I made the titleblock 24x36 and you can see that it scaled the dwg. down.
    All AUGI, all the time DanielleAnderson's Avatar
    2004-06
    Mostly in Mom-land
    704
    Default Re: Printing with Revit PDF Writer 4.2
    Dumb question, but did you click on "fit to page" or "zoom 100%"?
    AUGI Addict aggockel50321's Avatar
    2003-05
    Waterville, Maine
    1,748
    When printing to pdf, in the Revit print setup dialog, is your zoom set to 100%? If its set to "fit to paper", you'll get the reduction in size.
    2005-04
    Saintlouis Missouri
    529
    All this time and all I had to do was put it at 100%. Thanks, I feel so much better.
  1. Printing- Revit to CutePDF writer issues
    By luna.j.francisco741580 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-11-02, 09:15 PM
  2. /more OpenGL - DWF 3D Writer and Revit
    By ws in forum Revit - Hardware & Operating Systems
    Last Post: 2007-06-12, 02:37 PM
  3. DWF Writer 3 / Revit fix
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2006-04-12, 07:39 PM
  4. Revit PDF Writer 4.2
    By jhensley in forum Revit Architecture - General
    Last Post: 2006-03-21, 06:56 PM
  5. Printing to DWF Writer 2 crashes
    Last Post: 2005-08-12, 05:25 PM
