Results 1 to 10 of 10
Thread: Convert Ellipse to Polyline / Convert multiple Lines into Polylines
    2004-11
    22
    Question Convert Ellipse to Polyline / Convert multiple Lines into Polylines
    There was a great little post about changing splines to poly lines earlier - and I could use some more help in similar areas.
    #1) Can Elipses / Elipse Arcs be converted to poly lines as well?
    #2) Is there a way to convert all of the lines in a drawing to poly lines at once - even if they're not connected? (This, unfortunately, is not a situation where I can just use PEDIT, JOIN, and select everything with a crossing window).
    2001-12
    St. Louis
    5,406
    Talking Re: Convert Ellipse to Polyline / Convert multiple Lines into Polylines
    Quote Originally Posted by luke.ottinger
    I know this doesn't answer your question, just wanted to throw it out there...
    set PEDITACCEPT to 1 to avoid that annoying 'this isn't a pline, would you like to turn it into one?' prompt (I believe this was added in 05? but, I could be wrong, it could have been there since r12 for all I know)
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2004-11
    22
    Default Re: Convert Ellipse to Polyline / Convert multiple Lines into Polylines
    You're right, doesn't answer the questions, but it is still a valuable little time saver. Thanks for the tip!
    AUGI Addict madcadder's Avatar
    Too far from the beach
    1,054
    Quote Originally Posted by mes0945
    Not in A2k2...
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    You can use the pedit command and then type "M" for multiple lines/arcs. Within that same routine, you can join all of the previously selected entities to join and then use a fuzz factor from 0.0 to whatever to join your lines/arc that are not connected at end points.
    2004-11
    22
    That certainly helped with turning all of the lines into polies - but - my eliptical arcs aren't converting.
    Alright, I've attached the file I'm working on for everyone's amusement. I'm attempting to take these pieces, make the entire piece 1/16" thick. This will all be cut from a metal lam and applied to a panel. Anyone have any ideas or at least feel my pain?
    0,0,0 The Origin
    8,570
    AFAIK existing ellipses cannot be converted to plines. If "Pellipse" is set to "On", all subsequent ellipses with be created as polyline approximations to ellipses.
    The Mpedit command - depends or your acad version and, for some versions, if you have Express Tools installed.
    2004-11
    22
    Thank you Danger Mouse!
    13,656
    Hi
    Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
    ID: TS59474 - Change true ellipse into polyline
    Have a good one, Mike
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by Mike.Perry
    Hi
    really complicated set of instructions to accomplish something so seemingly simple don't you think?
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
  1. Convert Polylines to AEC Polygons
    By medwards.119413 in forum ACA Wish List
    Last Post: 2008-12-14, 11:48 PM
  2. How to convert polylines into arcs & lines ?
    By Jema in forum AutoCAD General
    Last Post: 2007-08-20, 07:02 PM
  3. Map 3D 2006 - Convert Solids to Polylines
    By nokiya2000 in forum AutoCAD Map 3D - General
    Last Post: 2007-01-11, 01:31 PM
  4. Convert Splines to Polylines
    By juliefrancoeur109665 in forum AutoCAD General
    Last Post: 2006-04-03, 09:14 AM
  5. convert an ellipse into a circle?
    By jm.pearson105333 in forum AutoCAD General
    Last Post: 2006-02-20, 08:04 PM
