Results 1 to 6 of 6
Thread: is that curve really tangent?
    AUGI Addict Maverick91's Avatar
    Grand Prairie, Texas, USA
    1,233
    Default is that curve really tangent?
    Howdy y'all.
    I'm working with an alignment in MAP. I need to determine if the curves and tangents are actually tangent to each other at their intersection. Is there a quick way to do this, without having to generate dims? Ulitmately I'd like to just pick a tangent and then a curve and see what the angle between them is.
    AutoCAD Civil3D 2013
    Gig 'Em, Aggies!
    Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice
    0,0,0 The Origin
    8,029
    Default Re: is that curve really tangent?
    Probably too simplistic but -
    line to arc : a line from centre of arc to endpoint of line will form 90 deg angle with original line
    arc to arc : a line between arc centres will cross at tangent point = endpoint of each arc.
    HTH
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2001-05
    Austin, TX USA
    2,201
    In map there is a command called _MAPCGANG. It also on the "Input and Inquiry" toolbar. When you start the command chose the points option. pick the center of your curve, then the point the curve intersects with the line, and a point on the line. If you get a 90%%D angle then they are tangent.
    Glenn Pope
    Civil Designer/CAD Manager
    River City Engineering
    AutoCAD Civil 3D 2011 Ver. 3
    Windows 7 Pro 64bit
    I explode MTEXT.
    1,233
    Quote Originally Posted by johnbogie
    HTH
    Yeah.. this is the one I'm trying to avoid.. oye! Thanks, though.
    Gig 'Em, Aggies!
    1,233
    Quote Originally Posted by gpope
    Kinda' figured you'd come though. That'll do it. Thanks!
    Gig 'Em, Aggies!
    2001-03
    13,499
    Hi Doug
    Please note I have *moved* this thread from the AutoCAD General Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
  1. insert tangent to
    By Liamnacuac in forum AutoLISP
    Last Post: 2011-10-20, 06:42 PM
  2. Grade In/Out on Vertical Curve Do Not Match Tangent Grades
    By technician.196935 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2009-02-22, 02:36 AM
  3. Deferred Tangent
    By .T. in forum AutoLISP
    Last Post: 2006-02-21, 07:03 PM
  4. Any way to draw an arc by tangent, tangent, radius?
    By christo4robin in forum Revit Architecture - General
    Last Post: 2005-09-01, 01:49 PM
  5. Tangent Circles not Tangent
    By ccowgill in forum AutoCAD General
    Last Post: 2005-05-10, 03:04 PM
