Results 1 to 6 of 6
Thread: Publish - Layouts not initialized
    All AUGI, all the time BCrouse's Avatar
    2003-04
    Bethlehem, PA
    980
    Default Publish - Layouts not initialized
    I have a question concerning publishing. When you add drawings to the publish dialog box. In the Status column I get Layouts not initialized. What cause that to happen? This happens when I publish dwgs that were done in Model Space.
    Thank you,
    Brad
    Last edited by Glenn Pope; 2005-06-21 at 08:22 PM. Reason: Changed text so it could be read.
    100 Club rclayton's Avatar
    2005-04
    Harrisville, MI
    166
    Default Re: Publish - Layouts not initialized
    It means that there is no page setup assigned to Model Space. If you do not plot from Model Space generally, uncheck the Model option from the Add Layouts section of the publish dialog and Model Space will not be added to the list
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    I could be wrong but, if there is not a page layout saved for the layout that is imported it will give this error.....
    and if the drawing are done in modelspace only...that would explain it...
    But again....thats just the way I understand it to work.
    2003-12
    Palm Harbor, FL
    537
    dang it!....Robert beat me to it...(I guess I was correct)
    2005-04
    Harrisville, MI
    166
    Sorry BB, just trying to help. LOL Didn't mean to steal your thunder!
    2003-04
    Bethlehem, PA
    980
    Quote Originally Posted by rclayton
    Thank you very much for all your help!
    Thank you,
    Brad
  1. Save Page Setups to Layouts in Publish Command
    Last Post: 2007-11-08, 04:27 PM
  2. Publish not plotting layouts in order
    By Coolmo in forum AutoCAD Plotting
    Last Post: 2007-07-09, 04:49 PM
  3. Print mulitiple layouts via the Publish command
    By MPsico in forum AutoCAD Plotting
    Last Post: 2006-12-09, 12:46 AM
  4. Replies: 5
    Last Post: 2006-09-14, 03:09 PM
  5. Replies: 2
    Last Post: 2006-07-24, 06:08 PM
