Thread: Mitered Walls Intersection Default
    2003-05
    East Walpole, MA
    893
    Default Mitered Walls Intersection Default
    This a message from a non-coder (that is, I'm not even quite sure what API stands for!!), but it sounds like an opening into the software code. Is it difficult to insert/alter a line so that "Mitre" is in lieu of "Butt." Yeah, yeah, I understand that when a framer makes a corner he doesn't mitre his plates, but come on, for our visual purposes, especially from perspectives and for clean VIZ images, give me MITRES!!.
    Geof Narlee.
    I could stop if I wanted to Danny Polkinhorn's Avatar
    2003-12
    San Francisco, CA
    448
    Default Re: Mitered Walls Intersection Default
    Geof,
    This setting is not exposed in the API that I can see. The only Application settings that are available are the library locations and the location of the shared parameter file.
    Sorry,
    2003-05
    East Walpole, MA
    893
    Thanks, Danny.
  1. Walls sweeps at roof intersection
    By mmiles in forum Revit Architecture - General
    Last Post: 2008-05-18, 04:33 AM
  2. Mitered corners (of walls) by default?
    By ron.sanpedro in forum Revit Architecture - General
    Last Post: 2008-04-03, 09:04 AM
  3. Default Coarse fill pattern for walls?
    Last Post: 2007-11-20, 03:36 PM
  4. Dimensioning and intersection or aparent intersection a no go.
    By kb3cxe in forum AutoCAD LT - General
    Last Post: 2006-05-08, 04:32 AM
  5. Default setting for mitered wall joins
    By narlee in forum Revit Architecture - Wish List
    Last Post: 2005-03-02, 02:57 PM
