Thread: Installation Failures!!!
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    Default
    We need some help. Anytime we install revit with the following setup, see attached .doc file We get the an unrecoverable error has occured...
    The machines are new dell optiplex, with the patches/services packs on the .doc file.
    Has anyone had any problems with any of these.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
    2003-04
    Irvine, CA
    6,776
    Default Re: Installation Failures!!!
    We just received 12 new Dell Optiplex units and we've not encountered any installation failures so far. I'll take a look at the patch history tomorrow. Are you saying the last hotfix is the "one" or one of the list and you don't know which is "suspect"?
    2003-05
    Coast to Coast
    4,439
    I don't know which one does it, the IT guys here push that entire list at once on to each new machine. If I install revit before they do that, no problem.
    Scott D. Brown, AIA
    HHCP.com
    2003-04
    Irvine, CA
    6,776
    If you guys are using the same kind of software we are, then set up a Revit install Action Profile (Powerquest's term) for them and have them run it in front of their patches. I use Revit.ini to establish our networks shares in Revit and PowerQuest fills in the users initials for worksets.
    I realize that's not an answer, but at least you don't have to worry about the installs.
    AUGI Addict andrewg's Avatar
    2003-05
    Waterville, Maine
    1,748
    I had that problem (using a Dell Optiplex gx150) about 8 months ago. The automatic windows update icon informed me of new security (i think) patches, I let it go ahead & install them, & Revit crashed everytime I tried to start it, so i just uninstalled the patch.
    This past summer I was upgraded to a gx260 & no problems so far, & the windows update says I'm current. Attached is the list of hotfixes installed, & it seems a little different than yours.
    I wish I could remember what patch caused the problem, the machine is no longer here...
  1. Revit MEP Success or Failures
    By clarkmorgan in forum Revit MEP - General
    Last Post: 2008-05-07, 06:48 PM
  2. Help with installation
    By moshe.118064 in forum ACA General
    Last Post: 2007-01-04, 05:56 PM
  3. surfing for failures
    By perezdeftone1988 in forum AutoCAD General
    Last Post: 2004-09-02, 08:43 PM
  4. fillet failures
    By perezdeftone1988 in forum New Forum Users (Non technical)
    Last Post: 2004-09-02, 07:35 PM
  5. Autocad Authorization Code Failures
    By bmkannan in forum Software
    Last Post: 2004-06-30, 03:19 AM
