Thread: Filled region doesn't work properly in wall based family
    100 Club A3D's Avatar
    2005-01
    Barcelona, Spain
    126
    Question Filled region doesn't work properly in wall based family
    Hi everybody!
    I try to do some some plumbing families that would act like a 3D model without being one.
    Description:
    I use filled regions inside a detail component for each view to mask whats behind.
    I load these detail components in a standard wall based plumbing family.
    Problem:
    Look at the attached file. While side and top views of the toilet display correctly, the front view (the one corresponding to the placing side) sometimes displays wrong, sometimes displays right.
    In the south elevation you can see the problem.
    What I tried:
    I tried setting the detail component in a reference plan that is offset from the wall - not working.
    I changed the hatch from solid to no pattern - not working.
    I don't know what else to do - it's quite FRUSTRATING.
    Thank you
    Update 2005_06_26
    If you create the same family as a non wall based plumbing fixture it works. It will work as well if you nest this newly created family inside a wall based one.
    However I would like to know whether this is a bug if there is something wrong I do.
    Last edited by A3D; 2005-06-26 at 07:26 AM. Reason: Added an image showing the problem for easier viewing;
    2005-01
    Barcelona, Spain
    126
    Question Re: Filled region doesn't work properly in wall based family
    Hi,
    I still face the same problem... can't get wall based families with filled region detail components to show properly. Am I the only one?
    Thank you
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Filled region doesn't work properly in wall based family
    You need to draw a ref. plane a slight distance from the wall and set it as your workplane for your filled regions. Even with solids if the two solids are in the exact same plane the surface pattern will show through one into the other.
    Scott D. Brown, AIA
    BECK
    2002-02
    St. Louis, MO
    4,695
    Sigh.
    I guess this should be a sticky as it seems to come up once every two weeks....
    See:
    http://forums.augi.com/showthread.ph...ht=lightweight
  1. Filled Region in symbol nested into family doesn't SHOW
    By gsucci in forum Revit Architecture - Families
    Last Post: 2016-07-23, 02:51 AM
  2. 2014: Wall tag w/ multiple colored filled region family types
    By thomas.denney836893 in forum Revit Architecture - General
    Last Post: 2015-06-19, 02:00 PM
  3. 2012: Plumbing Valves Symbol Filled Region doesn't Shown
    By jackcai1026 in forum Revit MEP - General
    Last Post: 2012-07-09, 09:13 AM
  4. 2011: Model based filled region issue
    By dgt.mantis in forum Revit Architecture - General
    Last Post: 2011-07-20, 09:44 AM
  5. Filled Region in symbol nested into family doesn't SHOW
    By gsucci in forum Revit Architecture - General
    Last Post: 2007-06-13, 04:08 AM
