Does anyone have an adjustable size garden window style I can borrow? I'll give it back I promise.
Phil
Phil
Dumb question but what is a garden window? (We probably call it something different where I'm from)
Jason Goodwin
Using ACA 2012
I can't see how that is a dumb question. A dumb question is the one that is not asked! The garden window that you are referring. Would it be used like a small green house for planting flowers or herbs?Originally Posted by arcadia_x27
Give me a day or two and I'll get you one you gave have.
Brad
I'd describe it as a window that sicks out of the wall about 18"-24" like a bay or bow window only its a small box with a slopping top. It consists of a single pane on the front one on each side (at 90 degrees) and a slopping roof type top element. I've seen them built in 2 ways, either with venting side panels or a glider type front. If I remember correctly (it's been a long time) they are about 30"-36" wide and about 40" tall.
Dave described it perfectly.
Still haven't found one.
Phil
Try manufactures sites. ie marvin, anderson, crestline.
If you don't find a cad file of what you are looking for, e-mail them and request one. About the only other option I can think of is to make it, but that's going to be a challenge. You could try and start with a bow window, but I don't konw if you can get all the correct planes. Depending on what you want to do with it, consider just making a mass element, or a multiview block. you could then just add and opening to your wall, and anchor the window to the opening.
Just a thought.
SEE IF THIS IS WHAT YOURE LOOKING FOR
Jason Goodwin
Using ACA 2012
Not quite.
The sidelights are 90 degrees to the front picture window.
Usually there are no grills.
It's looks something like this, only is a window, not a mass element.
Does it look like this picture
My mass element has that shape.
Maybe try a window assembly?
I don't do much with windows, but it's another thought.
