Thread: Text fades in mtext box using a LCD monitor
    2005-03
    2
    Question Text fades in mtext box using a LCD monitor
    Hello
    i am using AutoCAD 2004 with a LCD monitor, OS: Windows XP, the problem I (we) are having, I am in school, is that when we use mtext command the text fades while we type in the text box the back ground is white or black(we tried with both colors) and the color of text is cyan. this does not happen with a CRT monitor I checked at home. does anyone have any idea what we can change or do to the settings (AutoCAD or in Windows)?
    Thank you
    All AUGI, all the time Alex Page's Avatar
    2003-07
    Wellington, New Zealand
    796
    Default Re: Text fades in mtext box using a LCD monitor
    Not quite sure what you mean (!) but think this will fix your problem...:
    1. Open your PC's display properties (NOT AutoCAD - right click on your desktop)
    2. Under 'appearance", "effects' unclick anything that mentions 'smooth edges of screen fonts"
    Note that this happens with both lcd crt monitors etc, but maybe your display properties are set up differently on your crt
    Hope this helps
    Alex Page
    RevitWorks Ltd
    Check out the Door Factory, a door maker add-in for Revit
    2001-03
    13,499
    Hi
    Plus check out the following thread in the AutoCAD FAQ Forum -
    The text in the Mtext editor is faint and very hard to read.
    Have a good one, Mike
    Houston
    7,543
  1. LISP from AEC-Curve Text to MText or Regular Text
    By BoarsNest01 in forum AutoLISP
    Last Post: 2010-06-03, 02:46 PM
  2. Text to Mtext
    By bowtle in forum AutoCAD Annotation
    Last Post: 2008-05-06, 10:51 PM
  3. text to mtext
    By jimmy.157171 in forum CAD Standards
    Last Post: 2008-01-25, 03:59 AM
  4. Text 2 Mtext
    By gbelous in forum AutoLISP
    Last Post: 2007-12-06, 01:55 PM
  5. TEXT TO MTEXT
    By dmorgan in forum AutoLISP
    Last Post: 2007-09-11, 08:31 PM
